Keep the tire camber under control and the tire inside the well. Lower is better for aerodynamics, but don't expect your "handling" to improve as suspension is designed to operate only within designed travel and angles. Exceed these and you will have less control than designed.
I'm not coasting, I'm shifting slowly.
