Old 02-16-2012, 05:13 PM   #8 (permalink)
ProDarwin
Originally Posted by UFO View Post
Keep the tire camber under control and the tire inside the well. Lower is better for aerodynamics, but don't expect your "handling" to improve as suspension is designed to operate only within designed travel and angles. Exceed these and you will have less control than designed.
This, somewhat.
The effect of lowering on your suspension has a LOT to do with the geometry and type (Strut vs. double A-arm vs. straight axle, etc.) Cars with good geometry can be lowered a TON and still have very good handling (or better due to stiffer springs and lower CG).
But basically... lower = lower CdA, so its better for economy.
