Old 02-17-2012, 08:43 AM   #670 (permalink)
sawickm
ReVolt Enthusiast
Originally Posted by MPaulHolmes View Post
The plan is to do a driver board for the low side, driver board for high side, and then control board. low side on bottom, high side stacked on that, and then control on top of that.
Hi Paul,
I sounds like your AC Controller will be packaged similar to your new DC Controller (your PCB stacking concept). Are the driver PCBs going to be compatible for the AC & DC Controllers? Could you use the same driver PCB for the AC & DC Controllers? Or are they completely different circuits? Is it compatible with IGBTs or MOSFETs or both?
How is the testing of your new DC Driver PCB going
-Mark
