Old 02-17-2012, 09:35 AM   #5 (permalink)
jamesshaw89
2007Prius - '07 Toyota Prius Base
90 day: 44.4 mpg (US)
1996s10 - '96 Chevrolet S10
90 day: 20.01 mpg (US)
Thanks for the heads up on the front air dam guys. I'm going to revise it to stop level with the belly of the car as well as be parallel with the ground. Using an 11" piece when curved and angled bows up in the middle. After I get that sorted out I want to figure out some kind of air splitter for the front tires and boat tail for the rear tires.
I cut the coroplast to make the side skirts last night I just need to go by lowes and get 1x6 pine board to put between the wheels to attach it to. The 4 inch wide board seemed too narrow as the tread part of the tire is about 6"
I can't believe how good this thing coasts in neutral and so far 3 out of 4 times the motor doesn't start up at 41 mph like it does if your in drive and feathering the gas.
Is there a way other than neutral to have the motor not start up at 41 mph?
I need to look up coast down testing today and use my garmin 305 gps watch I use for running to gather the distance and timing data.
