Old 02-17-2012, 09:34 AM   #10 (permalink)
SentraSE-R
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
Originally Posted by mans View Post
I was concerned about this...
An electrical engineer is telling me resistors work by wasting off the extra electricity into heat.
if thats the case the motor would use 7 amps regardless of the control knob setting, as at full power none would be wasted to heat, and the lower you go the more is turned into heat...
but when u put an ammeter to the car you will see that power draw DOES go down when u turn down the control knob.
This difference between what I find in actuality and what the electrical engineer tells me is confusing.
can anyone shed some light on this one?
It's all there in Mort's post #7. The power consumed (wattage) remains the same, but the amperage through the fan motor drops to half if the resistance in the circuit doubles by your adding resistors.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
