BAD to WORSE. Please help.
SOLVED. See Post #19
Ok,
1992 Geo Metro 1.0, automatic
Today I cleaned the engine bay. Then, I replaced the cam seal, timing belt, distributor seal.
The geo will not start now. I am getting gas and fire. Do you think I got water some where or it is a timing issue?
On the timing issue - I was VERY careful not to mess it up. IF, I had one tooth off on the timing belt, shouldn't it still run? I noticed that the distributor will only go in one way and I am pretty sure that I installed it correctly.
Any ideas? Any and all help would be greatly appreciated!
Thank you.
3585 pounds of twisted steel.
Recreational | Active | Vehicle | 4x4
...scratch that... AWD
