Old 02-17-2012, 07:44 PM   #58 (permalink)
oldbeaver
Mercedes 89 D - '89 Mercedes 300 E
90 day: 33.86 mpg (US)
Skodie - '09 Skoda Octavia TDI PD
90 day: 38.84 mpg (US)
1993 Mercedes 300D Turbo - '93 Mercedes Benz 300D Turbo W124
90 day: 26.19 mpg (US)
Crossie - '16 Subaru XV Crosstreak
90 day: 9.61 mpg (US)
90 day: 33.34 mpg (US)
On-line aero calculator: good, but ...
Aerodynamic & rolling resistance calculator - EcoModder.com
Back in the day, krousdb made a spreadsheet to calculate aero & rolling resistance forces against his del Sol, their respective power requirements, and effect on fuel consumption at various speeds.
I've ported/expanded the spreadsheet into an online tool which asks you to enter or accept default values for...
- vehicle weight
- Crr (coefficient of rolling resistance - .008 represents a low rolling resistance tire on a smooth surface - see Wikipedia for other sample values)
- Cd
- Frontal Area
- Fuel energy density (in Watt hours / US gallon)
- Engine efficiency
- Air density (rho)
... and it spits out a table showing resistance force values, estimated power requirements and fuel consumption across a range of speeds.
It's online at EM here: Aerodynamic & rolling resistance calculator - EcoModder.com
It's not perfect (e.g. engine efficiency changes with load in real life, but remains fixed at the value you supply for all speeds in the calculations for fuel consumption).
Discussion, questions, suggestions welcome.
Excellent work! However, who knows what is the frontal area of a car? As it is important, car makers should give that measure to the owners. Maybe someone knows a link where to look for this variable?
Mercedes 300 D turbo 1993
