We pulled a Geo Metro engine out of 3 feet of water in a river (on an air boat that sunk) and after replacing the ECU, putting new plugs in it and draining the water out of the crank case it fired right up, a little bit of water sprayed on it shouldn't harm your engine, if you are getting spark and gas then it should fire, make sure that you have good spark plugs and like has been said already, that your timing is correct with your firing order in the right order and it should run.
