Thread: Carb Swap
Old 02-19-2012, 02:03 PM   #2 (permalink)
drmiller100
constant velocity generally are not as good as many of the two barrels.
if it were me, I'd use an EMPI or Weber version of this:
New 32/36 DGEV Weber Carburetor
there are a bunch of versions - basically there are mirror images of this one, and then various ways to run the choke.
For temperatures of 60 degrees and warmer, you can adjust the choke to where it never comes on.
These are easily tunable, and the very small primary means they are EASY to adjust, not tempermental at all, and very drivable.
Should get good gas mileage as well.
The Following User Says Thank You to drmiller100 For This Useful Post:
sankyp (02-20-2012)
