Old 02-20-2012, 01:48 AM   #257 (permalink)
ERTW
ERTW's Avatar
Bu - '08 Chevrolet Malibu LS
90 day: 32.29 mpg (US)
so...21 hours later...I realized how to drastically cut calculation time.
Results for a sharp nosed revolved template - 295 N total drag => Cd = 0.178
The frontal area is 3.0656 m^2 (60" tall, 5" ground clearance)
air speed is 30 m/s (108 kph or 67 mph)
air density at 20°C is 1.204 kg/m^3
I realised that from 70% to 80% of the template is a straight section, whereas I use a curve. Phil, if you were expecting a lower Cd, I strayed from the template, as you can see, and this is what I got. This software has good correlation. I didn't want to go beyond solid models and get into surfaces, so I'll leave it at that.
It's expected, and still pleasant confirmation, to see the surface pressure *increases* near the very tip of the tail. I made the nose sharper because there was a large high pressure area on the blunt nose.
Tomorrow will be an interesting day at the University of Toronto
Name:	Aero template mod surface plot.jpg
The Following 10 Users Say Thank You to ERTW For This Useful Post:
aerohead (02-20-2012), BamZipPow (02-22-2012), blownb310 (02-27-2012), Cd (02-20-2012), ChazInMT (02-20-2012), KamperBob (02-21-2012), landsailor (02-22-2012), NeilBlanchard (02-20-2012), skyking (02-20-2012), Vekke (04-14-2012)
