Old 02-20-2012, 02:59 AM   #5484 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Yes, if you give it small throttle, it will try to do that same proportion of max current. if your max current is 1000 amps, and you do 10% of max throttle, it will ramp up pwm duty until you get 10% of 1000 amps, but that will never happen at 12v. It's a pretty easy fix to calibrate the current sensor.
kits and boards
