Old 02-20-2012, 06:33 PM   #17 (permalink)
aerohead
hitch
Originally Posted by Snowman9000 View Post
What to make of the fact that when towing a fifth wheel travel trailer, with the tailgate installed, anything in the truck bed that is light enough to be picked up by a person can be picked up by the air flow in the bed? Most fifth wheel owners find this out the hard way on their first trip.
This must be a bad thing aero-wise?
Some people pull fivers with no tailgate, and some with a vented tailgate. I haven't tried either. If I do, and the hurricane disappears, does this mean anything from an aero point of view?
What if the hitch could just emerge from a bed cover, would the bed cover reduce drag? For instance, imagine a modified gooseneck hitch arrangement, in place of a fifth wheel hitch, where the ball is at the top of a bed cover. If it could be mechanically sound, do you think it would reduce drag?
I'm not knowledgeable enough to properly address your drag question but my instinct would be to run with the gate up,to allow for the locked-vortex inside the bed.
Comparing a conventional,non-sleeper tractor to a C.O.E. tractor,the C.O.E.tractor has 15% lower drag simply because it's height is equal to the trailer height.
For both types of tractors,a 31.25" gap between tractor/trailer adds another 19% drag.
So anything which can fill in and blend these interfaces should show at the pump.
As far as raising the hitch point in order to run a bed cover.I think that it would negatively impact the center of gravity and how the rig would handle in emergency maneuvers when dodging Ken and Barbie.
