doax that is impressive, i build microcontroller circuits and write code in assembly. if it works well and does not fail its a good design!. for thermal protection you probably already know that you could use negitive or positive temp coefficent thermisters and an op amp to trigger where ever you calibrate it. we use them on our lasertag vests charging systems. im interested in these kits for the pruis,,, i dont have one yet but i am eyeballing them, because of the avalibility of kits to up their mpg. my echo is getting long in the tooth at 199k. and 70 mpg is promised on some of these kits,
