I've done a grille block and extended the angle a bit so it is not so vertical, I've also put an airdam on the front and done a partial belly pan at the front, This is to improve aerodynamics as well as improve airflow through the engine bay.
The results from the engine bay re temperatures have definately improved, the aerodynamics seem to have a placebo improvement, will wait to see FE numbers on the next couple of tanks.
Good to get some insight on the windscreen issue so I can focus my attentions on the bigger fish.
