bschloop
The Yamaha 185, sounds like a winner, If you are going to have a fan give some thought to putting it behind the motor, rather than in front. I suspect though that if you get the ducting right you will not need a fan. You should also have some ducting behind the motor to insure good air flow away from the motor. If done well you may only need a very small fan as insurance when standing still.
