Old 02-22-2012, 09:25 PM   #6 (permalink)
roosterk0031
If you use your finger to push the pin to let it out it will get cold and possibly frost bit. Poke it with a screw driver and see if anything leaks out. Or just take a joint apart and watch for refrigerant leaking, it's just a gas with tiny bit of oil you probably won't see.
They sale the stuff at walmart so it can't be that dangerous or enviormentally unfriendly.
