Old 02-23-2012, 01:56 PM   #35 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by ps2fixer View Post
I use to "drive smooth" around corners etc probably around 10mph. Now I try to keep moving a bit faster when possible 20-30mph depending on traffic, corner, etc.
When keeping up the momentum, you don't need to accelerate again.
That's where the benefit is.
Coasting up to these corners also help - see where and at what speed you can start coasting to arrive at the corner with just the right speed to make it around it.
On the interstate / highway, I've chosen a speed that I can keep driving at, even in the turns where different roads join up.
SO I get both the benefit from driving slower, and from not accelerating.
Another thing I have noticed helps is to let off slightly on small hills and loose a little speed and gain it back on the backside of the hill.
Yup, sure works.
You're trading in kinetic energy (speed) for potential energy (height) and swap back when going downhill.
I should go back to killing the CC when going uphill (or small inclines / overpasses rather than hills around here).
One more thing, following larger trucks at a safe distance seems to be a benefit
It definitely is, but there's some debate about what distance is still safe.
The safer / further you are, the lesser the benefit.
