Welcome to ecomodder !
Originally Posted by scifi
I recently put on delta wing vortex generators on a 2005 scion xb with good results so far of course it is very square and flat sided.
You're one of the first people on ecomodder to actually get good results with them.
Could you elaborate a bit on how many / where you put them on ?
(You'll need a few more posts before you can add links or pics in your posts though - anti-spam measure .
Leaving out the
part and maybe split up an URL will help though
Ive been using a kiwi scanner to keep track my latest run is up from 29.3 mpg to 35.2 mpg even stopped by two places on the way home I always reset the kiwi and drive the same speed 60 miles per hour, 30 miles each way.
What was the variation in mpg before putting on the vortex generators ?
Ideally, they should be tested in near-identical situations, under the same driving conditions (speed, distance, previous warm up, traffic density, ...)
That ain't always easy though.
