Old 02-23-2012, 04:52 PM   #42 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by rmay635703 View Post
I disagree, we already can burn LPG, CNG & gasoline efficiently in the same engine. Diesel & E85 would just be icing on the cake.
Combining gas and diesel (spark-ignited & compression-ignited) in the same engine is very tricky. Variable compression ratio is one thing, but changing from 10:1 to 20:1 is a big challenge. Modern common rail diesels also run fuel pressures up to and above 30,000 psi. Piston shapes are much different. Cylinder heads & ports are shaped differently. Plus, these days you need aftertreatment (catalytic converters, DPF, SCR, etc.) which are completely different for gas vs diesel.
That's not to say it can't be done. I think it was Case/Farmall that made a tractor engine that started on gasoline and then switch over to diesel.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
