Old 02-23-2012, 05:40 PM   #44 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
After treatment is a difference. However, Mazda's skyactiv direct inject engines have pistons quite similar to a diesel.
There are a wide variety of piston bowl shapes, but it you put that thing in a diesel it would smoke like a chimney. Here's a more typical diesel piston
In a direct injection gasoline engine the fuel is injected a long way before top dead center, with the goal being to vaporize and mix the fuel before ignition. In a diesel the piston bowl distributes the burning fuel plume. For this reason, a gas direct injection injector is pointed almost directly downward. A diesel injector is typically more horizontal than vertical, because the fuel in injected near TDC and the shape of the piston spreads out the fuel to mix with the air.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
