Old 02-23-2012, 10:06 PM   #48 (permalink)
niky
Difficult, unless you decontent the diesel.
To keep prices down, you'd have to remove the variable geometry turbocharger (not necessary anyway, if you're maintaining constant engine speed) and go with a fast spooling low output unit. It'd still be more expensive than the gasoline unit, and weight would be a problem unless you give it an aluminum block... which would cost more still.
A perfect match would be a 1 liter 2 cylinder or a 1.5 liter 3 cylinder. You would need extra work to make them smooth enough... but maybe the vibration from the engine would be incentive for people to plug in their cars more regularly.
