Old 02-24-2012, 01:01 AM   #15 (permalink)
mort
EcoModding Lurcher
mort's Avatar
Originally Posted by mwebb View Post
it would seem the pressure difference can be attributed to change in the ability of the engine to pump air into the combustion chamber
with a closed throttle as opposed to wide open throttle
with extreme suction throttling losses or almost no suction throttling loss
that difference clearly exceeds 5% .
Hello mwebb,
You are confusing pumping losses with throttling. They aren't the same. Your graph dosen't show any information about pumping losses.
-mort
