Old 02-24-2012, 01:08 PM   #4 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Congrats! I found out thge same thing with my truck. Once you learn the lights well, you can to a great job. It does lend itself to a natural P&G. One or two will always catch you, but that's just the way it goes.
As far as the engine off operation, my truck has 3 postions: off, run, & start. When I EOC I go from run to off (which shuts off the engine) and then switch back to run. That turns the lights and all the electronics back on but doesn't start the engine. I can bump start in the run position or switch to the start position to engage the starter.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
