Old 02-24-2012, 01:42 PM   #5 (permalink)
graydonengineering
graydonengineering's Avatar
Frontier 2wd 2.4L 5 speed - '98 Nissan Frontier XE
90 day: 27.87 mpg (US)
Originally Posted by Diesel_Dave View Post
Congrats! I found out thge same thing with my truck. Once you learn the lights well, you can to a great job. It does lend itself to a natural P&G. One or two will always catch you, but that's just the way it goes.
As far as the engine off operation, my truck has 3 postions: off, run, & start. When I EOC I go from run to off (which shuts off the engine) and then switch back to run. That turns the lights and all the electronics back on but doesn't start the engine. I can bump start in the run position or switch to the start position to engage the starter.
Do your turn signals work in ON setting with engine off? I will have to try that out!
-Miles
Best 15-mile commute city/highway mix: 37.7 mpg
Best tank so far: 31 mpg
