Old 02-24-2012, 04:54 PM   #8 (permalink)
Speeed3
You can check vss/mile with known distance. If the known distance is 10 miles just set vss to 100 and the distance mpguino shows is vss. Discard the decimal marker.
Injector delay is time injectors take to open it is subtracted from each injection pulse.
You can ad injection_pulses/tank display keep track of what mpguino displays your tank gallons and injection_pulses were and what gas pump gallons were. It will take 2-10 tanks to get the delay.
Or you could just leave delay as is.
