Old 02-24-2012, 08:46 PM   #61 (permalink)
roosterk0031
Tighten that belt.
PS pump is on back side of engine, on bottom, have to lay on back, loosen bolts, put crowbar start pushing and then try to tighten belt. If it wasn't for my 14 yo girl learning to drive with it, I'd remove the PS. Hear a grinding noise on way to work this morning, part of the rocker panel was rubbing on rear tire.
I really don't think it's possible to get it tight enough, even warm the PS is dieing, it's not that cold here often enough that driving 3 minutes at lunch isn't easier, only twice so far this winter.
