Old 02-24-2012, 11:49 PM   #4 (permalink)
jime57
OurInsight - '06 Honda Insight
That's a 2.5% improvement from the grill block. That is about what most folks report, though the accuracy of most measurements is a bit dodgy.
Inside or outside the grill work shouldn't make much difference. You are basically just shutting off the lossy flow through the radiator and engine compartment. The actual shape of the grill block makes little difference as the entire area is a high pressure point.
