Old 02-24-2012, 10:57 PM   #108 (permalink)
eq1
eq1's Avatar
I'm just about finished with my stick cycling regime... I've mostly been posting this and that question and info over at insight central, in this or that thread. But I still plan to post some 'results' here...
I've got 1 1/2 sticks to go and I'm trying to resolve a couple things before I put everything back together. One question involves measuring/calculating internal resistance. Basically, after 4 cycles on each stick I went back to the lowest capacity sticks, 5 of them, and did another cycle, with slightly different settings. And then I decided to do another cycle for all of them at these different settings.
So, when I discharged this 5th time I was more careful about documenting initial voltage and voltage under a 3.5 amp load - at 1 minute for each stick. From what I've read I can calculate the sticks' internal resistances by subtracting the loaded voltage from the initial voltage and dividing the result by the current, 3.5A. For example: 8 volts initial, 7.5 volts under 3.5A load at 1 minute, divided by 3.5, which produces 0.143...
My question is, what are the units for that 0.143? 0.143 ohms? I've looked all over and tried to figure it out, but I haven't found anything definitive. I have a Panasonic technical sheet that lists 2 milliohms as the 'internal impedance' of a single cell (12 milliohms for 6 cells I presume), but the conditions are a little different, such as a 'current' of 1000hz. I don't understand that... Overall, my sticks are ranging from 0.13 to 0.17... 12 milliohms would be 0.012 I believe, so something seems amiss in my calculations...
Thoughts?
2000 Insight MT, CAN, ~168k Miles
