Old 02-25-2012, 09:17 AM   #110 (permalink)
eq1
eq1's Avatar
Excellent, thank you...
So, using my example, if it were 8000 mV, 7500 mV, and 3500 mA, the result would be N mOhms? The result is 0.143, the same as before...
Also, I asked this question over at Insight Central, but haven't gotten an answer: Do you know the pair-ordering of the subpack pairs as monitored by the 10 voltage taps? The OEM numbering of the sticks, as seen from the circuit breaker side, is:
-bottom row, left to right, 1-7
-middle row, right to left, 8-14
-top row, left to right, 15-20.
I want to make sure my relatively weaker sticks aren't paired up...
2000 Insight MT, CAN, ~168k Miles
