Originally Posted by Ed-in-Maine
Hi All,
I've scrounged up some power tools and will start building my truck Duck Tail and a small "Teardrop" camping trailer.
Teardrop trailers all have too much / too fast a drop on the rear .
They often end up as nearly semi-circular, the kind of shape you really need to avoid on the back end.
Basic dimensions are set at 4' wide, 4' high and 8'-10' long(could go a little longer if that helps).
Longer helps - it gives you more volume, and the tear
drop can be longer / less steep / more gradual, so it more closely matches the streamline template.
