Material for tail?
I am having trouble finding the coated paper that Vetter is using for his aero tail/ trunk so I am considering some alternatives. I could use .020" aluminum at $3/ square foot but it will be prone to dent. I wonder if Coroplast would work well or if the open core would be a problem with water in freezing temps. I see they also make signs out of Lexan which I can get in .020 which is supposedly possible to be cut with scissors and should be flexible enough. Will it crack around screw holes?
