Sendler, I just finished skinning my new tail section today and I used coroplast panels on the sides and plasticized sign paper for the rounded top. The coroplast is very easy to work with and pretty rigid in line with the tubes. I built my framework with 3/8" and 1/4" plywood bulkheads, light wood and sheetrock edging stringers. The coroplast is very light and provides additional stiffness to the tailsection. The more I use coroplast the better I like it. Plus if you are an election sign harvester like me its free!
I'm not sure about the lexan but I think it's too brittle to be a good siding material.
