I like to think about these types of questions like this:
Friction = energy lost to heat
Suppose I am loosing 1hp of energy due to friction. That means I am loosing 746 watts of power in the form of heat. That is a lot of heat! I can't imagine bearings that are in decent shape heating up by any significant amount. Certainly not anywhere near 1hp, which itself is a very modest amount of power.
The pads on disc brakes remain in contact with the rotor even when the brake pedal is released. This constant friction is so low as to be negligible because the force of the caliper is not pressing the pads against the rotor.
I'm sure a brake system could be designed that retracts the pad away from the rotor and eliminates friction altogether, but the tiny savings would not justify the added complexity.
Where am I going with all this; if it ain't getting hot then it ain't reducing your MPGs.
