Old 02-26-2012, 02:27 PM   #269 (permalink)
ERTW
ERTW's Avatar
Bu - '08 Chevrolet Malibu LS
90 day: 32.29 mpg (US)
I'm already ahead of you drmiller...the solver finished this morning after 12 hrs and 373 iterations!
I learned a huge lesson this morning. The goal plot was pretty flat at 100 iterations. Even at 200...and then around 220 it became a step function It was flat out until 350 iterations - and I was ready to stop the solver there...and then another step. wtf! It goes to show that what I assumed was "substantially" accurate may not be. I'll just let the solver finish from now on!
A moving floor becomes useful below 5" of ground clearance. At 13", it's more free air, than ground proximity. If the under body is rough, then it may be of benefit to drop the car, and force more air over the body. If the under body is smooth, it's more beneficial to have higher ground clearance. It's a trade off that's best explored in a wind tunnel.
I have the tail at 15°, and it still appears to detach somewhat. I hypothesise that ~12.5° is max. I believe the largest loss is the vortices. I think we could stop streamlines from migrating from the bottom, around the sides by widening the tail...more like a duck tail than a point.
rho = 1.205 kg/m³ @ 273.15 K
v = 30 m/s (108 kph)
A = 2.138 m² (23.0 ft²)
Fx = 108.68 N
Cd = 0.094
Drag index = 0.20 m² (2.156 ft²)
did I do good papa?
Name:	streamline front.jpg
ID:	10350   Click image for larger version
Name:	streamline bottom.jpg
ID:	10351   Click image for larger version
ID:	10352   Click image for larger version
ID:	10353   Click image for larger version
The Following 10 Users Say Thank You to ERTW For This Useful Post:
blownb310 (02-27-2012), Cd (02-26-2012), ChazInMT (02-26-2012), jime57 (02-27-2012), KamperBob (02-27-2012), NeilBlanchard (02-26-2012), skyking (02-26-2012), slowmover (02-28-2012), t vago (03-21-2012), Vekke (04-14-2012)
