Old 02-27-2012, 08:52 AM   #64 (permalink)
markf
Volt With No Name - '12 Chevy Volt # 5083
90 day: 79 mpg (US)
Originally Posted by trooper Tdiesel View Post
how far has any one gone on a single full charge?
any one cracked the 50 mile mark?
where at a fixed 0.06 power rate 24 hours a day, so that would be a good bit less then the $1.10 a charge im seeing
My max so far is 44 mi range on a single charge for my usual 65 mi work round trip. I've only had the car since last Fall and thru this Winter, so I expect to beat that number once it gets warmer.
My lowest battery range was 19 miles, under exceptional circumstances: air temp 9 F (-13 C), hideous wind chill, front & rear defoggers on plus wipers to cut the snow off the windshield, inside heat set to my usual 80 degrees and seat heaters on 2/3, ABS/TC firing left and right to keep me on the road.
