At some point, common sense has to play a role in your thought process serial. You dismissed a technology based on a few calculations made after reading the article. At least one of the engineers on the project was listed as a doctor; don't you think he is capable of those same calculations? You are talking about maybe gaining one horsepower as being feasible, but a device that can put out 6kw isn't? I am sure it won't put out as much power at light load, but that is fixed with more battery.
Come to think of it, look at your own post. A turbocharger is more efficient than a supercharger because it uses exhaust energy instead of crankshaft energy to power the forced induction. Why does that efficiency difference suddenly disappear when one uses exhaust energy to drive a generator instead of the crankshaft?
