Old 02-27-2012, 11:18 AM   #5 (permalink)
yostumpy
yostumpy's Avatar
wallace - '98 landrover 300tdi defender 110 hard top
90 day: 24.56 mpg (US)
Originally Posted by jakobnev View Post
The best way to accelerate with a TD is by simply flooring it and using the revs where it develops the most torque.
When not accelerating, neutral coasting can be used with good results when the engine is not needed.
so mid range power then! ie no benifit to creeping up to speed gently with little throttle? I'm still abit blonde with regards to the workings of a turbo deisel. presumably when you hoof it (not too much) then your not overfueling it like a petrol then, ie all fuel is used. But do you actually mean 'floor it', as that kind of goes against my thinking.
