Take off the filler neck and hole saw it.
For more oil capacity get the largest oil filter you can find that will fit.
So you want more boost?
Good suggestions. I will do those.
I THINK I want more boost... right now, the turbo starts dumping before max RPM and output. at maybe 80% of that.
I'm going to try SeaFoam to address the crankcase venting...maybe a stuck ring because of sitting outside unused for a couple of years. I might also spray some PB Blaster in each cylinder overnight (unless someone tells me that's a bad idea)
