Correct, a non-lean burn fuel injected gasoline engine will adjust the fueling based on the O2 sensor readings, so as to keep the AFR right near 14.7:1.
On a turbodiesel with fixed geometry turbo decreased backpressure will give you a higher AFR. On a turbodiesel with a variable geometry turbo, it depends on how the controls work. In many cases the VG will adjust to keep the AFR the same, albiet at a lower exhaust manifold pressure, so the pumping losses go down.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
