Old 02-27-2012, 06:20 PM   #118 (permalink)
ogregev
Originally Posted by IamIan View Post
I suspect the Super Brain also uses some of these other methods as fail safes ... for instance it has an optional temperature sensor could potentially be used for the dT ( change in Temperature ) , and the dT/dt ( Change in Temperature per unit time ) , and the TCO ( Peak Temperature Cut Off ) ... I suspect it also has a maximum peak voltage based on selected chemistry and selected number of cells ...
The SuperBrain 989 does have a temperature probe, but you're testing six cells and you're likely to have only a single cell overheating, so it's kind of useless.
I contacted the company and they couldn't make a six-sensor adapter for any reasonable money.
