Old 02-27-2012, 07:19 PM   #119 (permalink)
eq1
eq1's Avatar
If I'm not mistaken, you're just describing "background charging": The car will top up the pack at a relatively low amperage while cruising, without lighting any bars on the charging side of the display.
If you're sensitive enough to your normal "fully charged" ... lean burn window, you'll notice it's harder to enter or hold...when background charging is happening...
Hmm, that thought crossed my mind as well. Now that I think about it, there was one instance when I saw some charging at non-normal regen times, sort of around this time when I was seeing the gauge dip to 16 or 17 and then pop back up...
2000 Insight MT, CAN, ~168k Miles
