Old 02-27-2012, 11:57 PM   #9 (permalink)
Frans
Wow, 5kg is very light8-)
I have found these in the America but not yet in NL.
I will keep looking.
In the meantime a short update :
- Exhaust leaks at b-pipe and at the back box.
- Intake tube is very small compare to the normal ESI or DXI (1.5 1..6). Still searching via carclubs here.
- Former owner(s) were not very smart /wise in problem solving. There was standing water under the rear seats and boot. So need to adres this first.
- Radio/audo has been cut and reconnected bycrownstone/screw so needed to be welded back into place.
- Water came from the rear ventilation flap that was not sealed in.
- Rust at the rear lights
- The licence plate lighting was from a completely different car, so does not fit and has been Monkey worked the 4 philips screws sticking out at the back
And most imported the first refuel has been made with the sade result of 1ltr/11,11km :-(
Anyway, just to give you all an update on the (is becoming ) project.
Best regards
