Old 02-28-2012, 10:02 AM   #7 (permalink)
Olympiadis
oldschool
Olympiadis's Avatar
White2003Focus - '03 Ford Focus SE 4-door sedan
Team Ford
90 day: 38.53 mpg (US)
White2001S10pickup - '01 Chevy S10 extended cab LR
Last 3: 24.51 mpg (US)
1989DodgeOMNI - '89 Dodge Omni
Last 3: 30.38 mpg (US)
1991ChevyC1500pickup - '91 Chevy C1500
Last 3: 24.03 mpg (US)
White1986Irocz - '86 Chevy Irocz LB9
Last 3: 30.14 mpg (US)
1999 C5 Corvette - '99 Chevy Corvette
2008 Infinity G37 - '08 Infinity G37
It sounds to me like it is your torque converter locking that is giving the increased MPG.
To test this you might try tracing your TCC circuit and then wiring in an over-ride switch.
Most newer vehicles use a PWM type of TCC activation strategy to make this function seem smoother to the driver. Even my S10 had this.
An over-ride will force a signal for 100% lock-up of the TCC at will, and will instantly show you the gain on your S.G.2.
Some (perhaps most) TCC circuits supply 12 volts to the pressure solenoid, and pulse the ground signal based on calculated duty cycle. In this case you would over-ride the ground signal using a SPDT relay.
Single Pole Double Throw (SPDT), Single Pole Single Throw (SPST) Automotive Relays
The Following User Says Thank You to Olympiadis For This Useful Post:
johnunit (02-28-2012)
