Originally Posted by skeeterb
will you be writing any code for accessing the BMS with a computer since you want to use a BlueTooth, RS232, or USB to access it?
I am a very bad PC/user interface programmer, and I hate that
I am an hardware and embedded software developper, it's why I want to open code and protocol to permit a very generic platform usable on any EV, with a lot a technical possibility and possible evolution.
At the beginning, for the bluetooth my idea was to dowload the datalog from the BMS directly with a smartphone, instead plug/unplud SD card, because the mother board is generaly under the hood, not easy to often plug/unplug the SD :/
And also, the smartphone can become the display of the dashboard, no need for the display option for those which have a smartphone.
