Old 02-28-2012, 11:58 AM   #98 (permalink)
oil pan 4
Originally Posted by payne171 View Post
I would love to hear why it is more efficient to spin a supercharger with a turbine than the crankshaft, but not more efficient to turn a generator (switched reluctance, which is a key part of the process from what the article said)
The difference between a super charger and a turbocharger is the super charger is a pump bolted on to the engine being driven by shaft power.
A turbocharger is a heat engine. A brayton cycle engine.
The brayton cycle is purely driven by waste heat from the diesel cycle.
A turbodiesel is a combinded cycle heat engine, more efficient than a diesel cycle with an extra pump attached.
Later I will tell why a turbine driven alternator would suck.
