Originally Posted by ogregev
...BTW, you can retrieve the results of the last 8 operations afterward. Go to the voltage screen and press down (or is it up?)
A, a, but not after you've pressed "stop", right? This means that, if you've set a rest period with zero trickle, you still have to wait after the last charge...
And also, 8 operations means that if you were doing 5 cycles you'd lose data for the first discharge/charge...
