Yes, all of this data is from my daily 20 mile commute down I-25. It would be good to test on longer trips; I will keep this type of testing in mind if the opportunity comes up. I also intend to re-do this test with my commute this summer, of course the fuel will be B100.
I think I have compensated for the warmup time with the grille block, as I could not run it with the EGR enabled without my temperature rising over 200 before I got to work.
I'm not coasting, I'm shifting slowly.
