Old 02-28-2012, 09:24 PM   #28 (permalink)
oil pan 4
Originally Posted by rmay635703 View Post
The reason is typically reliability but also the fact that your engine is not going to automatically increase in efficiency as compression ratio goes up, in fact it can go down because of the massive dynamic frictional losses, egr and blowby
The highest production compression ratio I could find was 22.5:1, so I find no reason to try and reinvent the wheel. I am sure the OEMs found good reason not to go to say 27:1 or higher.
After every one went NOx crazy that was one of the reasons C/R stayed low.
I have no EGR.
EGR = BAD
The dragster and pulling tractor diesels run C/R as low as 14.5:1 but take over 100lb of boost. Not built for fuel economy.
My water injection pump and pressure control system is all ready to go, just waiting for warmer weather.
