Old 02-29-2012, 07:09 AM   #103 (permalink)
Air-Hybrid
Originally Posted by serialk11r View Post
Currently, nothing is being done to capture waste heat.
Traditional turbos do capture waste heat (as has been said previously).
Turbo-diesels are a perfect example of this - where downsized engines give the same power for better FE.
If I dare bring Ideal gas law into this thread (it seems to add to arguments in the BSFC thread for some reason!), can I just confirm that we remember that decreasing the pressure of a gas, say by extracting work across a turbine, will proportionately lower it's temperature - by the IG law.
My argument isn't that there isn't enough energy, just not enough waste energy... But I agree that this could be useful, it's something that should be implemented on all cars.
Isn't this a bit of a contradiction? (I'm not saying that to be rude. I'm just interested.)
I think the key is that, as you also say, all the big wins in IC efficiency are in the bag.
Regarding back-pressure on the engine, we know that none is bad and too much is bad. So I can't see why a well chosen turbine (non-supercharging) wouldn't remain within that sweet-spot of back pressure all the time. A handy effect of using a generator is that the ECU can determine the load (equal to back-pressure) second by second by wave-chopping the output.
BMW's steam generation system produced double digit improvements in efficiency under [peak] conditions
Unfortunately thermoelectric generators aren't very effective and steam based systems have high weight penalty...but there's so much potential.
Cost to the manufacturer comes into this as well though.
The turbosteamer idea is probably around three times as complex as exhaust-generator-componding. And it would conservatively cost twice as much to integrate. So it would need to give a minimum of twice the mpg gain as the turbo-assist.
... which it might, but no one really knows yet.
