Old 02-29-2012, 09:53 AM   #58 (permalink)
user removed
Originally Posted by serialk11r View Post
Yea I think so, was it Old Mechanic who gave the analogy with an aircraft running at high altitude where the air density was much lower? With the throttle plate closed it's almost imitating those conditions except the throttle restriction is adding a little bit of heat to the charge.
Never thought of it in that context before, thanks.
I always thought that high velocity air flowing through a restriction was cooler after the restriction. I also look at the atmosphere as a column of air that extends from sea level to the edge of space, that weighs a nominal 14.7 pounds, and is trying to fill any void due to mass and gravity.
I know that the grilles on buildings in the middle east serve as a form of passive cooling of the air as it passes through those grilles.
Bottom line for me is the Mercedes SB that claimed 7%. I never studied engineering in any formal classroom scenario, I did consider Physics for a short time, but ended up as an apprentice in a body shop at just past 18, and maxed out my Social Security contribution barely 4 years later. Pop could not afford to finance the education of his 4 sons. Today he is closing in on 91and can easily finance the education of his grandsons, if that is what they want.
regards
Mech
